Larger scale project w fibaro
Guest Kuuno
Just sharing a little larger project w Fibaro solution as here has been so much about what cant be done so now something that can be done
It is a Viking village consisting of a main house and group of 3 buildings w bedrooms some 50 meters away.
Main house has a Hc2 controller and 3 quest houses share a Lite (which is a slave for HC2)
from the reception one can choose which rooms are free or taken and according to that heating panel or holiday mode is used
Air heat pumps are controlled with itach's (ca 10)
regards
Guest David R
    great work kuuno
    • 1 month later...
    Nice project.
    What do you use to control knx in the Fibaro/knx video?
    I have a customer that's asking for this functionality.
