Notification timer?
I want to create a scene where if a device is turned ON for particular period of time then HC2/HC Lite should send a notification to my mobile.
Ex. If someone turned ON TV and is running for more than an hour I should receive a notification.
How can i write a scene?
WiYantra, trigger scene on some event (eg. turning on of relay or when power drained from Wall Plug exceeds some value), enter loop which counts time - send message when needed from that loop. Exit the loop when device is being turned off.
