Joystick 2
Hi all,
I have an issue with my new Duwi Wall switches. I bought 4 of them 2 weeks ago but only setup one in my closet.
What I did: Include switch in HC2, assigned 2 Fibaro relay switches to Wall switch via switch association (clicking 3 times on switch, then 3x on Relay)
Everything was working.
Then after a week the Wall switch suddenly died. It did not respond, even with new batterys configuration was not possible etc.
I used another one (new) and did the same as before (including etc).
After a week the switch was dead again, this time the battery was empty.
Does someone one know why this all happend, or where the problem is?
Do I have to include the switch to the HC2? Because actually it is working also without it...
Cheers
joystick
