Fibaro Alarm
I have some questions concerning the Fibaro Alarm. I want that if there is an Alarm that all blinds closes. I try to configure it with the "Scena Panic". I get the notification I want but the blinds doesn't close. What could be the reason for that. Or is there any change to program a scene that if an armed window is open the blinds closing?
I have the Iphone app... is it possible to Arm the whole system with just on push or so? Because arming 13 windows and other sensors is very boring....
Thanks and best regard
6 answers to this question
Have you changed the "Inactive" state of scene? It is next to scene name, in the same row as predefined scene.
To avoid arming devices one by one, go to alarm section and arm your system by rooms.
To arm and disarm you can use this lua snippet that Bamsefar wrote on Swedish zwaveforum.se
    Thanks for your help.... the Alarm Panel isn't working. I try everything with the Panic Mode but the blinds do not go down....
    Is there any chance to get a button like on the Ipad version to arm all my Alarm devices....
    MuM-Home, what version of firmware do you have?
    On iPad you just need to enter alarm section (upper right section of screen) and tap slider to arm all devices.
    my version is 4.021....
    Yes, it is perfect on the Ipad Version.... I would suggest that also the Iphone version will get that feature....
    thanks
    Oh, sorry i mistaken the iPad and iPhone apps you were talking about. As far as I know the Alarm Panel in beta has some issues, that is probably source of your problems.
