Would be a great option to have in HC2 ... like Vera and homeseer have
If blueiris is supported , then we suddenly have support for all the blueiris`s large camera list in Homecenter
Any chance this could be done ?
It works just point it at the mpeg paths for the channels
+ you can call fibaro api on motion of the cameras
  • 5 years later...
So Rob - many years on, are you still using Blue Iris and integrating it with Fibaro?  I'm thinking about replacing my Dahua NVR with Blue Iris and one of the main reasons is so that I can get reliable camera publishing to HC2.  (I realise I have to use MPEG video - my cams can do that on Stream 2).
not using Fibaro controller anymore but still use BlueIris
  • 7 months later...
Got the url from other website to trigger BlueIRIS recording
I would like to call the below when motion sensor = 1
http://BI_IP:81/admin?camera=Cam_ShortName&trigger&user=Admin&pw=BiAdminPw
how can I turn the above into lua scene?
Edited by MaverickLu
