Fibaro Door/Window Sensor battery low
Guest Axel
HC2 shows low battery for one of my sensors.
Changed battery wit a new one, but warning is still there.
Canged battery with another sensor, but still the same !!!
Any Idea ?
Not normal if you run 3.X but maybe normal if you run 4.X. What version are you running? It still reports open/close to HC2?
I think that sometimes happens when a battery device has not been fully configured.
