Hi.
I changed twice the batteries on my Fibaro Door/Window sensor, and it stills alerting me about low battery... What did I made wrong.
Tks in advance.
jnevestdl, You have to change battery with opened door
/emoticons/default_icon_smile.gif" alt=":-)" /> so the magnet is not in touch with door sensor.
    1st I made with the door closed... Then I opened the door and have done with door opened... Still does not work. I don't know what to do!
    Guest fat
    After replacing the battery did you wake the device up to ensure that it reports back to HC2?
    No. how can I do that? the simplest way?
    Thank you
    Just wait 4000 seconds (if you've not changed the standard setting) for it to wake up by itself.
    4000 seconds??? you mean 2,4 days? 66 hours?
    4000 seconds is just over an hour. That's what mine are set to, and I cannot remember changing it.
    To manually wake it up "quickly press the Sensor's internal TMP button 3 times - the Sensor's LED will flash slowly and the device will stay awake for 5-10 seconds"
    • 4 weeks later...
    After reincluding the door/window sensor in 4.03x the device doesn't have any parameters.
    I had contact with A.Socha and he said that it is an know bug.
    For me the device is working properly without those parameters. (I did a reset of the device).
    I have 7 door/window sensors and they are all working.
    One thing. You have to reinclude the sensor nearby the HC2
