Guest imparator
Hi, i have a alarm system
that have 4 0-10v ports that i can assign to his state.
i want to use this ports to let fibaro now that we are home yes or no,
if the alarm is on = we are not home. ( i can measure that the voltage drops to 0v from 10v )
if the alarm is off = we are home ( port 2 drops to 0v )
if the alarm is part on = we are home, but first floor ( port 3 drops to 0v )
how can i use the rugby module to let this work .
i test it with in 1,2,3 on the rgb module but it doesn't change from state
can someone help me out with this ?
why i want this ?
I want that when we not at home, the system put everything off that is in the list,
If we at home, everything on the first floor stay off, living room going on,
when the alarm is set to part on, then the living room is off, first floor is on.
