change device parameters with LUA
hi,
i want to change my device(ex:id=64) parameters throgh lua in virtual device but when i use the below code i get status code 400,
this also not work..same error
even change device name not work..same error
Please help
What response do you get? There is very limited access to changing parameters using put and post. The only success I've achieved is changing the isBatteryOperated parameter, but that switched back quickly.
My guess is that the json is formed from a database beneath and is constructed for the API. That is the way I usually do my programming. I have the data in an xml file or in a database and then have a script which constructs the JSON when requesting it. This also means that when you put or post anything (if it is even allowed) then you just change the JSON constructed for informative purposes, but the data beneath remains untouched. The system is not designed for the device parameters to be user changable through the api.
