Hi I was wondering if someone had an idea on what to do
Just replaced my reticulate on box with 4 2x1.5 relays
1. Bore
2. Zone 1
3
4
9 zone 8
How can I link the zones to the bore to turn on . Have to make sure bore can't be on without a zone turned on...
Is it possible in the 4.023 beta?
Hi Mad-Cat,
Easy! Just need some Lua code:
Just make sure you replace the "xx" bits with your device ID's (don't forget to put them into the header as well, all 8 zones and the bore!!!)
This will basically make sure that if any of the zones are on, the bore will be on too. If they are all off the bore will turn off. If someone tried to turn the bore on by itself the scene will also kick in and switch it back off again (providing you make sure the device ID of the bore is listed in the triggers section.)
Hope this helps!
Dan
    Hi Mad-Cat,
    Hope this helps!
    Dan
    Thanks man love to have ur level of skill in scripting.....
    Can't wait to try it out
    [ Added: 2014-12-18, 04:52 ]
    Hi
    Thanks again for the code is it possible to ask a question on the code.
    there where some or missing in the long line checking zone status ok.. now im getting
    [ERROR] 11:46:43: line 37: unexpected symbol near char(194)
    Sorry really don't know coding at all took me weeks just to read these basic ones.. getting better...
    thanks again
    %% properties
    274 value
    276 value
    278 value
    280 value
    282 value
    284 value
    286 value
    288 value
    %% globals
    local zone1ID = 276
    local zone2ID = 282
    local zone3ID = 284
    local zone4ID = 278
    local zone5ID = 280
    local zone6ID = 286
    local zone7ID = 288
    local boreID = 274
    local zone1Status = tonumber(fibaro:getValue(zone1ID, "value"))
    local zone2Status = tonumber(fibaro:getValue(zone2ID, "value"))
    local zone3Status = tonumber(fibaro:getValue(zone3ID, "value"))
    local zone4Status = tonumber(fibaro:getValue(zone4ID, "value"))
    local zone5Status = tonumber(fibaro:getValue(zone5ID, "value"))
    local zone6Status = tonumber(fibaro:getValue(zone6ID, "value"))
    local zone7Status = tonumber(fibaro:getValue(zone7ID, "value"))
    local boreStatus = tonumber(fibaro:getValue(boreID, "value"))
    fibaro:debug("Scene running")
    if (zone1Status == 1 or zone2Status == 1 or zone3Status == 1 or zone4Status == 1 or zone5Status == 1 or zone6Status == 1 or zone7Status == 1) then
       if boreStatus == 0 then
         fibaro:call(boreID, "turnOn")
     else
      fibaro:call(boreID, "turnOff")
    No worries, glad to help!
    I just copied your code back into my HC2 here and didn't get an error on line 37 - it ran just fine.
    Is this the exact code you have running?
    Cheers,
    Dan
    I tested it as well and it works fine.
