ok, i updated links in my oryginal post. Let me know if it works now
works now - thanks!
Cheers
Alfons
There is a wide range of rain gauge sensors for Z-Wave now, but why do that when you could have a load of fun make your own "Tipping-Bucket" rain gauge using a binary sensor?
Using something like a Qubino Module for the Inputs as their FLUSH 1 RELAY module gives you 3 x Inputs and can operate on 24-30VDC or 110-230VAC.
More expensive solutions include the Qubino Z-Wave Weather Station.
Hi smk23us,
I have a rather dumb question: I bought the KEMO rain sensor and a Fibaro FGBS. How do I do the cabling? I've connected the blue-white cable from the KEMO to IN1 on the FGBS, but nothing happens when I put some water on the KEMO (apart from the fact that the LED switches on) - Did I do the cabling completely wrong? Thanks - help most appreciated!
Cheers
Alfons
the kemo has 2 wires for the contact
connect the scond one to the blue wire of the ubs
Hi akatar,
did that - the blue wire from the KEMO is connected to the blue wire from the UBS, the blue-white-wire from the UBS is connected to the yellow wire from the UBS (IN1) - alas, no still no joy!
Cheers
Alfons
EDIT: Got it - took the wrong blue wire
/emoticons/default_icon_smile.gif" alt=":-)" /> Thanks again!
  • 3 years later...
Can anyone post image how to connect this KEMO with Fibaro Universal Sensor and with DC?
I want to create this setup but i'm completly new to the DC and wireing.
