Fibaro Motion Sensor scene
I created a scene at Kitchen , whereby once Motion is Detected(BREACHED) , then LIGHTs turn ON , the Once Motion is SAFE, the LIGHTS turn OFF, my problem is here , what if i want to be at the kitchen for some time or if i am eating ( not in the range of Motion sensor detection) , then the LIGHTS will be TURN OFF right...How is possible for everytime i need to make a notable movement at the motion sensor to make the Lights ON for some time..My biggest problem here how to make the manual switch turn ON overides the Scene even it ACTIve or Not ACTIVE...Please i need to someone guidance since im stuck with these issue for couple of months....
/emoticons/default_icon_confused.gif" alt=":-?" />
4 answers to this question
Why did you create another thread for this? You already created the other thread for the same problem...
    Hi stevenvd ..i thought someone could help me thatz why i post in here for Power User..apologize if disturbing..
    Hello Krisshnakumar,
    You are not disturbing. There are many people here who would like to help you, the only reason why I was asking is because mostly the following counts:
    If you ask 1 time: people tend to respond and help you.
    if you ask the same question in multiple places, people don't want to read two almost identical stories and don't know what to answer to...
    So my recommendation is that, if you post and think of more information, to just add it to your first post by editing it, or otherwise just by adding it as a comment.
    So it is was not that I or other people don't want to help
    To answer your question.
    You could try to enable scene activation for the dimmer. In that way you can enable a three time click to go in override mode. I think that that is the most easy way to do it, as all the standard behaviour will than not be changed.
    On how to do this in code with lua, you could search the forum for scene activation.
    Let me know how you go
    You could perhaps have it that the lights won't turn off until motion is detected elsewhere. or maybe add some pressure pads under the table or seats.
