marcfonteijn 4
Using the steps described in this articles (
) it's really easy to control HC2 through Tasker. Even though everything is in French it's not that hard to setup. The only thing I haven't figured out yet is how to press buttons on a virtual device so no I used scenes a a workaround.If you want to try this out I can also recommend downloading the AutoVoice plugin for Tasker so you can control everything through voice commands (in any language). Check out this post (
) about AutoVoice on this forum.4 answers to this question
