Valken 0
Good Day,
Can someone please help me with a script to achieve the following:
I have a ceiling fan with a light and 3 speed settings. I have created a VD with 4 buttons, One that turns the fan Off and the other 3 for the speed settings (Slow, Medium, Fast) using global cache ip2ir as the fan is controlled by infrared.
Now, i would like to make a scene that checks the Fibaro motion sensor's temperature and turn on or off the fan accordingly.
So, IF temp is above 26 Degrees - Turn on fan to low speed (Push button 2 on VD)
IF temp is above 29 Degrees - Turn on fan to Medium speed (Push button 3 on VD)
IF temp is above 31 Degrees - Turn on fan to High speed (Push button 4 on VD)
and if temp falls below 26 degrees turn OFF fan!
How can i do this?
Any help would be highly appreciated.
Thank You,
9 answers to this question
