Wall plug is incorrectly controlled by room light bulb icon
Guest minimax
Hi guys,
i've got two wall plugs which control washing machine and a dishwasher. They cooperate with a flood sensor and disconnect the power in case of water leakage (in cooperation with aqua stop water pipes).
The problem is that if wall plugs are on (all the time), the bulb icon of the room in the UI is turned on. If i turn it off, it disconnects dishwasher and washing machine. This is terribly wrong.
Both wall plugs are configured for controlled device as Other which should not lead to be interpretted as lighting imho.
Can you please advise a solution.
Otherwise I'll raise a bug.
HC2 /4.023
Offtopic - the system is now quite stable. Thanks guys for weekly updates.!
Cheers,
Petr
It has been reported for a Fibaro relay, not a plug, as
It's similar in behavior. I'd report it as a bug en let Fibare decide if they want to merge the two reports.
