Roller Shutter 2: Icon shows wrong state (awning)
laslo
Hi folks,
I recently got my new Fibaro HCL. I just want to implement basic things so I should be fine.
I installed a new Fibaro Roller Shutter2 to control my awning. The module is running in standard mode (roller blind mode with positioning active). After the calibration everything works fine.
When I use the standard icon (which shows a window) the icons shows the correct position of the awning. When I cange the icon to the icon showing an awning the position shown is NOT correct. When the awning is open it shows a closed symbol and a closed awning shows an open symbol.
I also did a calibration directly after I changed the icon... Nothing helps.
Does anyone know how to fix this bug??
8 answers to this question
Guest youka
Try changing the wire direction for output 1 and 2?
I'm wonder if it helped ?? I have exactly the same problem icons show opposite status for two blinds.
that would work but the awning would show on mobile devices as always (ON) or (OUT) even if the icon shows its fully closed! I have exactly the same issue with my projector screen a constant green light on mobile device even though its actually closed!
I did file a bug report about 2 years ago!
Did you ever find a solution to this issue as I have the same problem?
Regards
Steve
Easy for Fibaro to resolve but they don't seem interested. A simple 60 sec code...
If checkbox = true then
Value = foo
Else
Value = foo2
Got used to it looking wrong now it's been years!
Guest youka
I've changed output wires and it helped
My solution was to change the picture
Old topic but i have a similar issue out of the blue. I changed the wires and now my awning picture is gone. I cannot select it and have no clue where it has gone. Was awning default from fibaro? Since i can only select the default window. If this changed, does someone have the awning icon otherwise?
