Misipino 1
Hi all,
the Fibaro system can be integrated with existing electrical system without major building works and this is a great thing.
In many homes however, there is also an alarm systems with sensors and keys to armed sensor.
I wish integrate Fibaro system with anti-theft system.
To integrate sensors is simple with FGBS-001 (universal binary sensor).
Into existing alarm system, there is a input to connect external relay key to permit armed and disarmed sensors, and a output relay to connect lamp to indicate if system is armed or not.
To keys, for armed and disarmed sensors, I wished to use again FGBS-001 but the HC see this as a sensor.
So I use FGS-221 (double relay switch) but it is powered by 220V and there isn't backup when there is a blackout.
Relay1 on alarm system = closed if system is armed -----> IN1 FGS-221
Input1 on alarm system, if closed the alarm system switch to armed ---- OUT2 FGS-221
Someone have another idea to implement this function to Fibaro system? There is method to use FGBS-001 (12 Vcc) instead FGS-221?
Regards
