IP Camera no http stream - is Zoneminder a solution
Hi, I've been battling with a camera that does not offer a cgi/http streaming option.
I've been looking for new cameras however just came across Zoneminder. If I understand correctly this will record all the ip cameras plus offer a feed i could use for Fibaro. I would like to know if anyone has tried this and if this is a solution that could work for hc2 and the phone view. Thank you
7 answers to this question
    HIKVISION 3MP IP Camera DS 2CD3332 I
    Try
    And
    Also you can use channel 2 for different resolution etc...
    Looks similar to my trendnet cameras!
    Hi, I have given that a go. apparently it may work on the older firmware but not the current version
    You tried it in a browser as well? OK very odd but sorry I cannot assist beyond personal experiences! Good luck!
    looking at the CGI docs, I cannot see anything that supports streaming video over HTTP(S) and I spent a long time looking.
    Im having the same problem. Asked the seller for information. It's an Anran IP camera.
    All i have is this:
    rtsp://IPADDRESS:554//user=admin_password=tlJwpbo6_channel=1_stream=0.sdp
    It works in VLC, But it aint working in fibaro. And i tried others from the provider. But it just don't work.
    So if someone have a solution for this please share it.
