Customise Fibaro IOS Home Page
Hi to all
Do you know if is it possible to customize the home page on IOS Fibaro apps?
Thanks in advanced
Gustavo
9 answers to this question
gusqua, For now you can change sort order of any button on main screen of iPhone app. Just hold one of them to start drag and drop mechanism.
In iPad app you can customize your widgets (below energy graph on the main Home screen). You need to hold together two blue buttons (Home and back) for few seconds and you will go into widget edit mode.
    Worked great! Thanks!
    R.Inczewski: Thanks very much for this. It's solved my problem with how to get something to work from my Home screen in less than five minutes and I never even knew it existed!!! Why don't Fibaro make these things clearer in some document somewhere?! I've been with you guys for @6 months and I never even knew it was there til today when I read this.
    So thanks for helping me get something I needed out of the system but really we should know these things already!
    Ta, Dave
    maybe on paid training you hear such things!
    thanks for tip!
    Guest chaicka
    Hmmm...in the latest Fibaro for iPad app, I am unable to enter the widget edit mode you mentioned despite holding the Home and Back blue buttons for 10 seconds. Any tips and how does it looks when in widget edit mode?
    Update:
    The sequence seems changed. I have to use the right blue Fibaro button and left blue Back button together.
    The combo of center 'Home' blue button with left 'Back' blue button does not work.
    Update:
    Chaicka,
    The buttons you use now are the buttons that were meant in the first place, so nothing has changed, you just lisunderstood the post.
    Just telling you this to prevent confusion for other users.
    Frank
    Guest chaicka
    Chaicka,
    Frank
    Hahahaha... 'Home' button is misleading cause that is actually a forward button.
    The iPhone App still doesn't save the changes you make when changing the order within the rooms though?
