Android Tasker and Fibaro HCL
since there are no widgets of Fibaro app on Android, Id like to use Adnroid Tasker for some interaction with the HCL - can you pls advise how that works ( sorry Im having no clue ).
Id like to add som basic widget buttons to run the scene on HCL as well as use Android as the trigger for being home ( when connected to WiFi ).
Thanks a lot
In tasker make new task "HTTP GET". Server Port will be:
http:// username:password@xxx.xxx.xxx.xxx/api/callAction?deviceID=01&name=setValue&arg1=80
You need to change the red things - username and password to HC, IP of it, ID of the controled device and the value at the end. For me this turn light to 80 procent. To switch light on just change 80 to 0...
after the task is complete, you need to add the icon to it. in the task menu on the right bottom you can do so.
Then you need to enable tasker (if it is dissabled). To do so just press and hold the tasker icon on the top left corner of tasker.
Then go to your homescreen (android) and add widget to it - find the task. It will give you the option to choose which task to add. And its all done.
You can find good manual for that on this forum...
And even to do it by voice
    Fantastico, works, thanks a lot
    Or use your android wear watch
