FGS-221 - Can't switch off the light anymore
Hi
I use a FGS-221 for turning on/off the light. Since a week now I can't turn off the light any more.
Any Idea what could be wrong?
There is no scene active to control this switch.
Thank you
Angelo
Guest fat
Does the light turn off when using the switch? If not try turning the switch to off on the switch or via web interface and then try tapping the relay with the back of a screwdriver to see if that works. Sometimes the relays stick depending upon the type of light used
Like fat said, this could be a welded relay caused by inrush current. Here is a whole topic dedicated to the subject:
