The Fibaro RGBW shows led strip on a bath as a potential application - red light for hot water etc. I was wondering how to best implement this? Where and how to put the temp sensor and which one? I understand it would need to be at least IP67 waterproof sensor but which one? And how to place it?
Cheers.
Lukasz
9 answers to this question
    hm, like inside the bath?
    floating in the water?
    [ Added: 2014-12-29, 11:21 ]
    i have no idea how they did it but i would say this is the easiest approach?
    i was thinking something more.... well.. permanent
    I guess the outside of the bath itself dissipates heat too so maybe stick a sensor to the outer shell??
    you could use a battery power door/window sensor with a dallas sensor attached and bond to the underside of the bath and calibrate the temp difference?
    or use a binary sensor and have it powered for more accurate measurements!
    both will work nicely!
    in case of a dallas chip
    I got this one :
    even better
