Philips Hue plugin & Hue Tap Switch
Dear Fibaro-Dev-Team
After installing your Philips Hue plugin my Philips Hue CL Tap Switch doesn't work anymore. After removing the plugin, all went fine. Perhaps it's the new user the plugin create?
I can't find the plugin-code. Couldn't you opensource it so that all could help you evolve the plugin?
Nine
I have the plugin working although I have no clue how to make it turn on in Lua from a scene. Anyone has it up and running, maybe with color choice or gradually changing colors.
[ Added: 2015-01-03, 00:29 ]
Those are the actions according to HC2 Toolkit:
"actions":
"setMute": 1,
"setVolume": 1,
"turnOff": 0,
"turnOn": 0
fibaro:call(ID, "turnOff", "0"); and fibaro:call(ID, "turnOn", "0"); turns the lights off and on, not really pretty code I guess... Also, I can't find how to start a lighting-scene from within a scene.
[ Added: 2015-01-03, 00:55 ]
I also feel like the plugin creates ALOT of traffic on the Philips base station. When I use the plugin and change the colors quickly, the base station chokes and I have lights changing color for like a minute.
