gestel73 0
I have a magninon ipc-10ac (Aldi) Ip camera. it works with the HC2.
with this camera i can set 3 fixed positions, i want to control this with the HC2.
the command for this is: decoder_control.cgi?command=31
if set this in HC2 for example at the stop button, it works.
but i want to use it with a virtual device. i can't get it to work
i get the response: 401 unauthorized, The request requires user authentication.
user = admin
pasword is empty
[ Added: 2014-12-31, 14:36 ]
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> it worksPlease login or register to see this code.
