Thermostat wired
Guest Lode
Where can i find a thermostat that works wired but also on z wave.
I saw the Nest already and there is a plug-in.
Anyone using this ? Other alternatives ?
I use nest!... best purchase in my whole automation setup! love it
[ Added: 2014-12-31, 13:29 ]
nest protect i do not like... false alarms to much humidity sets them off etc... but the thermostat is great!
Guest Lode
    If you say so, no doubt it's good
    Do you use the plug-in ?
    I've been reading that the GUI is a bit of a mess.
    This is what i need :
    In the livingroom a thermostat that can be used with HC2 but in case of malfunction of HC2 i still can use it manually.
    Every room has a Danfoss valve.
    Bathroom and toilet do have a temperaturesensor.
    On my boiler comes a relay in case of heating demand in bathroom and/or toilet.
    This is quick summary but is it possible to achieve this ?
    Fibaros plugin works but looks rubbish! It cannot be selected as a room thermostat yet another bug in fibaro but the plugin allows full control if you need it... Lacks schedule data etc...
    Guest Lode
    Let's hope they will change the look of the plug-in .
    This is good enough for me.
    Schedule data is something you don't change that many times so i have no problem to do those settings on the thermostat itself.
    I just need it to turn on the heating when i leave at work, nothing more.
    How about the other things i mentioned above, is this possible ?
    • 9 months later...
    Hello everybody,
    i am asking about nest thermostat 3rd generation , is Fibaro has plugin For it or just have the 2nd generation ?
