Weather variable Pressure
Guest Charly
For my heating planning i would like to use the current Air Pressure. If there is a rapid change in Pressure there is also a change of weather.
As far as I can see there is no Pressure variable in HC2 available. Only at this moment Temperature, Humidity, Windspeed and Condition.
The Yahoo Weather API also gives the pressure, it should be easy to implement this in HC as well so we could use it in LUA.
I passed this suggestion to developer team, thank you for it!
Guest Charly
    Many thanks would appreciate the addition.
