Good morning Guys.
I've 2 question about FGFS-101 sensor.
Is there any way to distinguish tamper alarm from the flood one?
The main problem is how to write different scenes Tamper / flood.
If it's so which properties should I use in LUA script?
Can I disable tamper alarm so I've just the flood one?
Last question:
I don't understand how reset the tamper alarm from the hc2 interface, any idea?
I'm on 3.600 and the only flood sensor associated device is the HC2.
any lua script is welcome.
I also tried that - but no, it is not possible
Parameter 74 - select "tamper alarms inactive"
I think all "alarms" expire after couple of seconds and status comes back to "safe". I had some problems with 2 (out of 3 that I have) flood sensors and had to delete and re-add them to HC2 several times to start working properly. One of the incorrect symptoms was breached status lasting forever.
Piece of LUA that I use to notify me of possible flood:
    thanks Robert
    I'll try your suggestions
