pietervanstee 0
I've successfully connected and installed my ASR-ZW module on my existing heating system.
Including the ASR-ZW went without any problems and switching on and off the heating is flawless.
Because I have enough temp sensors in the house I'm not using the HRT4, but that's no problem.
However, I noticed that after about an hour or so my radiators turn cold, and if I check the ASR module, the two bottom leds are solid red. Turning the module off and on again starts the heating again without any delay or problems. (on the ASR itself or in the control panel).
Does anyone know what can cause this? what would I do to fix it?
If I can't find a good solution I can always write a script that switches the heating off and on for a minute or so, every half hour...
