U5tabil 2
Thanks to petergebruers for the involment on this.
I put it here as its working, and maybe someone might want to use.
For me, i use it to set when the heater should go on/off, depending on time of day and a temperature device. Instead of using a built in thermostat. I will add some more stuff to it later on.
Change value 72 for your own temperature meassurment device id.
Change value 79 for your heating device
In this example i set the heater to start when temperature is under 20 degrees and turn off when over 21 degrees. This to avoid it from going on/off like crazy. And also to be off during night. Later i will probably add some presence in house etc. Once i feel its a usefull thing.
This one will need a
of time_of_day.Please login or register to see this code.
10 answers to this question
