alkorsi 1
Hi all,
Today I had the following issue - in the module view of the HC2 my vision siren showed an almost full battery. And then while implementing a scene for it, I noticed that it isn´t working. I was not able to turn it on and after exchanging the batteries it worked again! So the battery indicator is not really reliable and I don´t know if the siren is still working or not!
/emoticons/default_icon_sad.gif" alt=":-(" />Do you have an idea how to check the device or to get notified if the battery is low? (I don´t want to turn on and of the siren manually every week(?!). Could this be checked by some coding or by a scene configuration - within the advanced configuration for the siren there is no default option to get notified if the battery is low as it is for fibaro devices!
Thanks and cheers,
alkorsi
