Sonos TTS + GEA
I have created a simple virtual device that send text strings to Krikroff's Sonos TTS virtual device. From GEA lua script on wanted time i press button in my virtual device to send the text to Sonos TTS.
Example setup:
GEA
My virtual device example
Another example
Source
GEA -
Sonos TTS version 0.0.8
You don't have to put any code under the buttons. Don't know if u use the Sonos program on your PC? If so, you just have to go to TuneIn, select a radio station, right click, info and options and "add to my radio stations". That's it.
I have those Sonos-players. I use 192.168.1.19, 192.168.1.20 and 192.168.1.21, that should do it, no?? Don't really know why associated ZP and kitchen are the same IP, maybe that's why it's not working. Do u have Sonos'es as stereo pair?
Associated ZP: 192.168.1.19
PLAY:1: Bathroom
Serial Number: B8-E9-37-B2-78-B8:A
Version: 5.2 (build 28183040)
Hardware Version: 1.8.3.7-2
IP Address: 192.168.1.20
WM: 0
OTP:
PLAY:1: Bedroom (L)
Serial Number: B8-E9-37-B2-84-5C:F
IP Address: 192.168.1.21
WM: 0
OTP:
PLAY:1: Bedroom ®
Serial Number: B8-E9-37-B2-8D-24:2
IP Address: 192.168.1.22
WM: 0
OTP:
BRIDGE: BRIDGE
Serial Number: B8-E9-37-1F-AA-5A:6
Hardware Version: 1.5.0.0-2
IP Address: 192.168.1.17
WM: 0
PLAY:1: Kitchen
Serial Number: B8-E9-37-B2-83-C8:3
IP Address: 192.168.1.19
WM: 0
OTP:
Guest David R
No sonos in stereo here
And only 2 variables? The variables, I took the top one, with only one value but the box always stays empty. Same for you?
Bridge or not? That "associated ZP" in your about screen? I tried readding the VD without success. When I press pause or play several times in 1 VD, I have several Sonos-players that change state, as if it doesn't take the IP into account. You just put the IP and port 1400 in the advanced screen on top, right??
Guest David R
Maybe someone can help me here. I try to use Krikroff's VD but it doesn't really work. I have 4 Play:1 and 2 are set to stereo.
1. I made the 2 variables
2. I made 3 VD's and just change the IP to the ip of the players and port to 1400
That's it
When I press the pause button on let's say Play:1 kitchen, that can pause kitchen or bathroom or bedroom, although they are of course different IP's. What am I doing wrong??
Edit: Seems as if the VD "runs" through my 3 rooms. When I set 3 different volumes in the rooms, the slider jumps through those 3 volumes in the VD and it does that in all 3 VD's...
Anyone knows what I'm doing wrong here? I guess something is wrong with my IP adresses.
I also have this same problem. Press play on the kitchen it starts. Press stop and it does nothing. press play again on the kitchen and it turns to living room on. press stop turns the kitchen off and leaves the living room on etc......
(close but no cigar)
Hopefully Krikroff finds this topic and gives some more info about it. I'm guessing we're both doing something wrong cause other people seem to get it working.
/emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I'm just wondering what Krikroff means by "maitre" in the info which translates as master.
Guest David R
I have sent him a direct message so we will see
Hi Tekvibes, David R,
Currently the module does not support MultiRoom and it is complicated to install multiple concurrent modules.
For each zone you should have a Master (the one that controls the other or others
/emoticons/default_icon_wink.gif" alt=";-)" /> )
Guest David R
Ok thanks! That's why it wasn't working then I guess! How do you group them together? Same IP? If people made 100% reliable and virtual devices... plugins and drivers for Fibaro I would pay a little price for them and I guess other people would to. Like Extra vegetables does for Control4! Idea for a business Krikroff,
/emoticons/default_icon_cool.gif" alt="8-)" />
What do you mean by master?? I now have 3 VD's, each with an IP of the Sonos in a room. That doesn't seem to work (pushing pause for instance on 1 VD can pause one of the 3 Sonos, whichever Sonos the VD wants at that time) How to get the VD to reliably control each Sonos? Thanks for the help!!
Guest David R
Tekvibes, I think Krikroff, is saying that it cant be done at this moment in time. Its all together or not.
OK.
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> There's a VD for HCL that can control different Sonos. Maybe I'll use that in the meantime till plugins mature a bit!
I also have 3 sonos speaker with 3 different IP adresses. Can't i just assign the VD 3 times? One for each speaker. But how to locate the right speaker for the usage of notification?
Guest David R
KristianO, You can try but you wont get the control you are looking for
I haven't examined the code that closely, but I think that you'll have to make a few global variables unique per Sonos Player.
Now, there are two global vars that the code is reading and/or updating: SonosLastCmd and SonosTTS. If you create a new VD for another player, find and modify all occurrences of SonosLastCmd with for example Sonos2LastCmd and SonosTTS with Sonos2TTS. Change in both the main function and in all buttons. Then create the variables and test.
That should work.
CQ1, yes it works fine
Is it possible to use IVONA TTS instead of GOOGLE TTS ?
I would like to play with the "Notifications VD "von jompa68 mp3-files instead of the TTS.
Is it possible and if yes how?
@krikroff: Everytime I update my HC2 with a new version/hotfix I need to re-save all my sonos VD, how come?
- Any plans for a new version? 1.0?
