Can't wake up dead nodes and other problems
Guest sk8er000
I've just updated to v4 but I'm getting some weird problems..
The most important is that some devices appears as dead nodes but if I click on the "X" and then "ok" nothing happens.
I've tried to reconfigure the mesh option but after a bit I get an error "receiving the list".
All this nodes were working before the update, and some of them are really near the HC2, one of them is at 30cm from the HC2 and appear as dead node.
also the smoking sensor is not working anymore, I get 3 icons: z-wave device, some sensor and temperature sensor stuck at 0.00
Everspring door sensor doesn't change its state
also some switches' icons are wrong and appear like an ON/OFF switch...
Tried to restart but nothing has changed..
Is there a way to fix these problems? These dead nodes are a real pain
EDIT
I did more test:
Smoke sensor: Problem solved ---> erased from the network and added again, now it works, still show 3 icons and I cant figure out what means the 3rd but is working.
EVERSPRING door sensor ----> tried to remove and add but did not work
Dead nodes: Still the main problem but they are still working on the scenes, for example the lights still turn on with the motion sensor (as I programmed) but I can't turn on/off from the interface toggle
EDIT 2
EVERSPRING Door sensor ----> after 4 removing/readding it works, but i had to edit about 20 scenes to get everything working again...I also got lot of problems due to general slowdown running automated tasks, especially with virtual devices..
Still got the problem with dead nodes, can't figure out how to fix this issue
[ Added: 2015-01-07, 11:34 ]
New day and new bug!
One of my rgbw controllers goes on (only on the interface) every time I refresh the page or I open a new HC2 page even if in the reality is OFF!
[ Added: 2015-01-07, 11:43 ]
OK, with a soft reset finally my dead nodes are working again.
The only problem is that they appear as generic switch and not as light switch and I if I try to change the icon I can't se any icon
problem with icons is fixed with version 4.031
Hopefully.
Can you tell us what soon means for you in that case (you know last time it was about a year).
Any other bugs fixed in this version?
Guest sk8er000
    Now Icons are fixed, I only notice some seconds of delay starting scenes and a general slow down on the configuation pages...I hope it will be fixed soon..keep up the good work!
