Fibaro Motion Sensor - Can't change prefrences
For some reason i can't make changes to the prefrences to it. Anyone else had this problem?
tried taking it close to the central even tripple click the button to get it alive to check. But nothing
It's a known bug. See
    So no solution to it? So i should just thow it in the garbage then or?
    I tried register on site but im not getting any email. what does it say? is there a solution to it?
    WTF what can we do?? It worked before...
    I dont know. im off to pick up another sensor at the mail office. Il experiment with that one.
    [ Added: 2015-01-07, 17:11 ]
    I just got a brand new sensor. opening right now. manage to add it to system, but i cant change anything with it.
    problem is fixed in version 4.031 who will be released soon
    So are Motion Sensors working again now or? Can params be changed?
    Do they work correctly and not turn into temp sensors any more?
    Dave:)
    Dave:)
    In 4.031 they work correctly after soft reconfiguration.
    Ah, at least I know now.
    Does the breach icon appear correctly too? Was missing in 3.60.
    KE, Dave
    They don't work, even after soft reconfiguration. It always makes "Routing table update" but does not receive the new parameters! Even reconfigure doesn't change anything.
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    To make it work i had to set the parameter to another value first and then to the one I wanted. Looks like the device and HC2 didn't have the same level of information.
