I've just purchased the HC2 and I am trying to upgrade it to a version >4 to be able to connect it to my netatmo weather station.
Unfortunately, All my attemps have failed with the error code : "Upgrade Error: 5"
Does anybody know how to solve this ? or what this error code means ?
the HC2 came with version 3.548 and I have two upgrade possibilities :
- v4.030
- v4.024
Thanks for your help !
Lionel
Try again. It seems from other users that when on 3.x you will first get 3.600 when you select 4.030 and then be able to actually upgrade to 4.030 from 3.600.
4 - Internet connection error - check the wiring and make sure that internet connection is available
5 - error while downloading info file from server - redo update
6 - error while downloading update package - redo update
7 - error while downloading update checksum - redo update
8 - checksum error - redo update
9 - error while extracting update package - redo update
10 - run.sh file is missing or is not an executable file - redo update
27 - error while copying files - redo update
30 - error while downloading a file with checksums - redo update
