Hallamnet 17
Good Evening all.
Having a bit of a challenge trying to get a script to turn on a blue LED strip @ 7AM controlled by a Fibaro RGBW LED controller when the outside temperature gets to 3Oc or below.
Idea behind it is I know when the car windscreen could be frosted over so its not a surprise when I go out to work first thing in the morning.
I have a fibaro Door sensor and connected to, a temperature probe from
and created the attached script to light the Blue channel of LED's if the temp is or drops below 3Oc.The only issue is that this does not work. In the screen shot, I have it set to 10 just for testing.
Can anyone help me out with this and tell me where I have gone wrong?
Thanks again,
Hal
