TKB Home and Aeon Labs parameters and so on
As our dear fibaro chosen not to support third-party equipment you must now enter the parameters for these plugs etc.
But where do you find them? I've Ever Spring Dimmer Socket, TKB switches, Ever Spring dimmer and Aeon Labs MicroSwitch
I am grateful for all the help you can get when fibaro does not make it easy for us
Johan71, we do support third-party equipment, but they simply do not have templates applied. Usually you can find all information needed in manual of devices, or simply ask its manufacturer. They do not depend on our system in any way, it is a matter of device itself.
I have a TKB switch myself. As far as I understand, you should set parameter 1 to 1, if you want to set the blue led to off when the device is off.
This isn't possible though, due to a current bug in HC2 4.031 - or j.nowacki?
- It is possible to add a parameter, but the value will always be 0 after the change is saved.
- It is not possible to delete parameter entries.
