After 4.030 update my sceneactivation script stopped working
Would be glad if anyone could help me with this
The script worked in 3.600 but now does nothing.
is there something i have to change?
check the debug to see if you have errors
/emoticons/default_icon_idea.gif" alt=":idea:" />
sceneActivation is broken for me with 4.031
Same here, sceneActivation doesn't work anymore since 4.03x
Tiens... sceneActivation working for me for minimote, Fib dimmer and Fib door sensor. I don't have any other device with scene activation to test with. Could it be that you own a certain device or device type that causes all scenactivation to stop?
This is the intriguing aspect of Fibaro sw releases
/emoticons/default_icon_smile.gif" alt=":-)" />. For me on 4031 scene activation works perfect (Fibaro dimmers and switches). Scene activation stopped working in one of the earlier 4.x releases for me because the property somehow got lost in the upgrade but was solved then by reincluding the devices - a bit of a hassle but it solved it then.
Can't be easy to hunt bugs at Fibaro
Here still not working 4.031
Same here, sceneactivation not working on a dimmer. I'm running on 4.031
the scene activation is working from temperature change so not universal issue.
This is my hot water heating scene debug trigger is change in temp
I have no dimmers so can't check that. Will check a few more scenes.
Working from value of a fibaro FGP111 Plug switch
and value from 3kw and 2*1.5kw
Does the device description in the Api still have an sceneActivation attribute?
http://[YOUR_IP]/api/devices/37
If it is missing then you have to (soft) reconfigure or reinclude your device.
I'm using a dimmer and it works in 4.031
No sceneActivation in api for the Zwave.me Keyfob, also not when I re-included.
And also not after soft reconfigure.
Soft reconfigure worked fine for me. I had a Fibaro Dimmer that stopped triggering sceneActivation after upgrade from 3.590 to 4.031.
Many thanks, Joost_NL! Now my only remaining upgrade issue is that the mobile clients are missing Universal Binary Sensor child devices.
A soft reset did the trick for me. Thanks Joost.
No sceneActivation shows up on my FGS-221 2*1,5 kW Switches when I do a soft reconfigure.
Everybody else see the sceneActivation on their switches when they check /api/devices/xxx for their switch?
sceneActivation worked in 4.03 and 4.031 for me.
In 4.03 a soft reconfigure was needed of the device in question to get it to work.
I started with a fresh system and after update 4.030 I added my devices.
DIMMER
If I use a dimmer then sceneActivation works:
SWITCH
If I test it with the "FGS221 Switch 2x1,5kW EU v2.1" then it doesn't work. I tried the device ID's from the master and the slaves.
SHOULD IT WORK?
But should it work? In the operation manual of the FGD211 Dimmer there is a parameter 41 which is all about the sceneActivation. They also talk about the roller blind switch.
In the operation manual of the FGS221 Switch they don't talk about sceneActivation.
Did it work before?
In my system it did work..
Now not.
Also tested your code...no succes
Option 41 is active.
Now not.
Do you use a dimmer or switch? If you use a dimmer look on the previous page because you need to soft reconfigure your dimmer.
Now not.
Parameter 41 for me on the switch is: Flooding Alarm set for Relay 2.
I think you are talking about a dimmer.
But why would a dimmer support it and not the switches?
Switches in version 2.1 not support that function
When can we expect to update our firmware then?
It's something that was advertised years ago.
Even I wanted to have answer on that, asked the same question in another thread.
