Hey all,
Got one of these nice little units but now 3 times in the last month it's gone strange and reports a real high lux value (like 134 or more). Only a reset and sync again makes it function normal.
Is there a known issue with these units or some parameter I can alter to avoid this mis-read lux value?
Seems to be the latest version : retrieved protocol version 3.67, app version 2.06
Any help appreciated
In version 4.031 a bug is solved. After installing this version you have to soft reconfigure your motion sensor.
    Hey!
    Thanks!. How do I upload the new firmware to the Fibaro device?
    thanks
    if you run the latest home center 2 firmware 4.031 indicated in the top left corner then you simply need to open you motion sensor (on the interface using gthe spanner) click soft reconfigure then go wake that little beauty up with 3 clicks and like magic lux will be alive again
    [ Added: 2015-01-12, 09:58 ]
    device firmware updates are not available to end users yet (as far as i know)
    Hi
    I'm on Indigo - gave up on HC2!
    [ Added: 2015-01-14, 16:09 ]
    Of course no OTA so can't fix.
    Hey Fibaro can I return them to you?
