Foscam F18904W issues
I have just started to configure my Foscam F18904W with HC2 4.031
Issue 1: If you configure the camera, by default the jpg images don't come out. The only way to do this is to add the following ?user=[uSERNAME]&pwd=[PASSWORD] to the end of snapshot.cgi
Issue 2: If you are using the wifi (wired works fine) on the Foscam, if you do the fix on 1 above you cannot connect to the camera at all after 10-15 seconds. The only way to fix is a full reboot.
Issue 3: I noticed that the Foscam F18904W has a specific plugin in HC2 4.031 - doing this, on wifi has the same affect as 2 and freezes the camera.
If anyone has any ideas let me know.
Yes, I've the same problems. However, accessing from an ipad for example, it works. Also from Fibaro app. So problem is located with pc browsers
Guest JBs
same behaviour with mime, I am not getting any streaming from the hc2 and it make the video cam hanging, even changing the connection string. Reboot is required to get it back and accessible from a browser.
