RTSP possible??
I have an ip camera that, as far as I can see, does not do MJPEG.. (
Is it possible to use a rtsp stream in HC2?
I have got the JPG thumbnail working.. But are missing the important part.. ;O)
4 answers to this question
No
Ace02, in some plugins cameras yes
A.Socha any idea which ones? even if you can name 1 or 2 of them? we have access to cameras but do not fancy trial and error
I installed all camera plug-ins
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> and I found that RTSP is supported in 2 EDIMAX Ip Cams.
I wanted use RTSP for a Foscam C1 that is not capable to stream Mjpeg.
No luck, I can't make it work with my Foscam. I tried all.
