erik.simonson 2
This post is most likely because I have not understood something correctly. I appreciate any help.
My objective: I have two electrically separated lights that I want to turn on/off synchronized by the installed Aeon Multi Switches (one switch for each light).
Current state: I have an electrical correct installation and the Switches have been included succesfully in the Z-wave-network of my HC Lite. I can turn each light individually on/off using the traditional old fashion existing electrical wall-switch as well as through smartphone-interface of Fibaro.
My problem: I have tried to set up association groups for the purpose of synchronoizing the turn on/off between the two switches, however unfortunately without success. When I switch either light on/off on the HC Lite it turn on/off both switches synchronized. It is only when I change state on one of the old-fashion electrical wall-switches that only the local light is turned on/off. The other light does not change state.
On both switches I have set parameter 80 (1d) = 2. (And the status is correctly presented in HC Lite including when I change on/off by using the electrical wall-switch.)
The switches has id 7 and 8 and HC Lite has 1. Attached is one picture including a snapshot of my most recent configuration of the association groups (I have tried quite a few settings....).
Could someone enlighten me if you have had something similiar to work? what have I done wrong? what could be tried instead? I would appreciate any explanations as well.
Thank you for all possible assistance.
BR,
Erik
4 answers to this question
