HSM02 contact detector and HC2 v4.031, bug?
Guest JBs
As I am switching from vera 3 to HC2, I'm progressively moving my modules and today was the turn of HSM02 detectors (I have 8 of them).
While moving the first one after changing its battery for a brand new one I noticed the following:
- Battery is in warning level (%)
- Device is causing the HC2 to display the yellow warning mark signal in its header saying the Zwave device needs to be reconfigured (whereas it seems to be working perfectly well)
If I try to reconfigure the device, it looses all its settings: room, name, icon. And the warning mark keeps being displayed ...
Also when I want to change the Wake Up Interval to set it to 86400 seconds, it never gets committed whatever reconfigurations I triggers, it remains set to 4000 seconds.
Has anybody has the same device and noticed any issue with them?
Guest JBs
    is there anybody using these Everspring HSM02 contact detectors with his HC2?
