pietervanstee 0
Hi all,
I've been spending some time scripting a scene that starts my devices in the morning, one by one, each with a time delay so it turns on at exactly the right time.
Here are some of my questions/problems I'm encountering while scripting (this and other) scripts:
My script will get started based on a time (wakeUpTime), but other than that there's an "autostart" and "other" trigger mechanism, can anyone explain me what it does exactly, can't seem to find a conclusive answer for this.
And following this question, are they essential?
Because of these different start mechanisms, I've tried to construct my action in a function(). To prevent repeating a lot of code within each trigger.
This function also gives me some problems, the function wakeUp() ... end works fine when it gets called indicated with the ******* in the script.
Then the function executes without problems, but if I try to use this function later on where the trigger is "other" I get an error: [ERROR] 15:38:47: line 32: attempt to call global 'wakeUp' (a nil value)
And my last question for now is about the tempFunc, is this just to restart the scene each 60s?
I hope someone can clarify some of my questions for me...
Thanks anyway;)
