3 click s1 on/off
Instaling new software 4.31 destroy mu lua scena:
triple click nothing happen. can someone help me?
Debug:
[DEBUG] 14:53:53: Dimer
[DEBUG] 14:53:53: nil
8 answers to this question
This is a known bug
Sometimes a dimmer doesn't convert 100% to the 4.X format. Im reasonably certain that sceneActivation will be repaired when you click on "Soft reconfigure device"
Edit: the message nil actually means the device doesn't have "sceneActivation"
    petergebruers, i use id of main device but also doesnt help^
    p.s. parameter 41 i turn on
    "Configure all devices again:Force re-configure all non battery operated devices, dead devices not included. Note! With a large number of devices that are not configured Z-Wave network may not be available for some time."
    is this what you mean about: "when you click on "Soft reconfigure device" "
    I am confused... Did I suggest you needed to use "ID of main device"?
    Did you click on "Soft reconfigure device" ? On the "advanced" page of your dimmer? It's between the heading "Associations" and "Configuration". Grey button. It's not the button "Configure all devices again" on the Z-wave screen - don't try that...
    DimaStud, please check if you got in api property scenActivation - you need reconfigure or remove and add again device
    A.Socha, now if i press run scene its turn on light, then if i press run scene it turn off light(rgbw controller). But i dont press dimmer. Its like last saved action(triple click) or another one. And if I use while true do, load of cpu more than 50% and it making light blibking(turning on-Off-On-off.......)
    p.s. also i cant change icon!for fibaro universal.
    What mister Socha asks is this... Please post the result of this url
    - replace the IP with the address of your HC2. So we can determine if the device is OK or needs to be excluded-included
    The result looks like:
    petergebruers, my result:
    [ Added: 2015-01-12, 18:28 ]
    ok, i dont know why but its start working )
    I prefer that to "it doesn't work, but I know why" - but maybe that's me
    The thing you copy-pasted indeed shows everything that 's necessary to have "sceneActivation". Happy hacking!
