Hi all,
Does the movement sensor react/trigger when a movement is noticed as well as when the lux changes? If so I just want to use it as movement sensor without reacting on lux changes. Which parameters I have to adopt to "disable" the lux sensor?
Thanks and cheers,
alkorsi
It will be the parameters 40 and 42 i think (or 60,62) in motion sensor. But basically it doesnt matter if it is on or off, the triger can be light OR motion OR both..
    mhhhh...within my HC2 version (3.590) there is option within block scene configuration to choose motion or lux change as trigger! You can only choose "armed and breached" (and some others)
    Yes that is correct but the motion sensor is split into 4 devices. Choose the motion device if you want to act on motion. Choose the light device if you want to act on light changes.
    many thanks for that hint!
