Aeon Labs Energy meter
Kage
Hello
I have my Energy meter included in HC2
Now i see only 0W
Tried to configured the parameters, but no luck so far
Where can i get the right settings for this
I'am living in Netherlands zo parameter 1 must be 240 so i gues
my settings for now
p1=240
p3=0
p4=50w
p5=50w
p6=50w
p7=50w
p8=10%
p9=10%
p10=10%
p12=0
p101=0
p102=0
p103=0
p111=720s
p112=720s
p113=720s
by the way its a 3 clamb
Kage, Assuming you have turned the power on ... 3 clamp and single phase 240 v ?
We are single phase 240v here in Australia, but single clamp ..which for me was reporting total usage in 4.031, but no live usage, so basically useless ..
Also checkout
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Playing the waiting game I suppose.
Cheers,
al.
  • I have read that topic and other ones, but no luck here
    don't understand your question mark over 3 clamp and single phase 240v
    240 ad parameter 1 tels it's EU and 230 is US, so i read
    we have just 220v
    /emoticons/default_laugh.png" alt=":lol:" />
    but thanks
    Is your energy meter connected with all three clamps and also the three voltage cabels connected to the right phases?
    Mine three clamp meter in 3.600 shows only total and phase 2 and 3.
    In version 4.031 shows everything perfect.
    Note.
    22oV ??? I think you have 230V in a single phase and 3x400V in three-phase connections.
    Hello
    Now i see only 0W
    my settings for now
    p1=240
    p3=0
    p4=50w
    p5=50w
    p6=50w
    p7=50w
    p8=10%
    p9=10%
    p10=10%
    p12=0
    p101=0
    p102=0
    p103=0
    p111=720s
    p112=720s
    p113=720s
    WITH THE FIRMWARE 4.031 THE Aeon labs Energy meter don't function !!
    Just parameter 101 size 4 to 16131
    I have installed the Home Energy Meter DSB09104-ZWEU with 2 clamps.
    It's possible to have all the parameters?
    [12] ID 133: Set parameter 101, value = 16131
    [12] ID 133: Received parameter 101 report, value = 6915.
    Many Thanks in advance
    Marco
  • isn't that for 3.59 settings
    when i included the aeon labs energy meter i get this
    I have Z-Wave Clamp Power Meter - three clamps Second Edition - Aeon Labs and I can´t get it to work. This is my advanced settings:
    Every parameter is on 0 and I cant change them, when I do they turn back to 0 again after I save. I have tested the clamps on an Vera and it showed correct so I know that it´s correct installed.
    It´s installed on three phase and a neutral system.
    Have removed it from the system and reinstalled with same result
    FIBARO!!!! PLEASE ADJUST THE FIRMWARE!!! THE AEON LABS NOT WORKING!!!
    swefred, uncheck "Use template for parameters" and then you can modify them.
    Suggested setting for HEM E2:
    1 : 240;
    3 : 0;
    101 : 3;
    102 : 16128;
    103 : 0;
    111 : 360;
    112 : 720;
    113 : 720;
    1 : 240;
    3 : 0;
    101 : 3;
    102 : 16128;
    103 : 0;
    111 : 360;
    112 : 720;
    113 : 720;
    Thank you for reply.
    If I uncheck "Use template for parameters" I get that all parameters disapperas
    I wrote alla the parametrar and saved, this is what it looks lik after. Totaly different values
    1 : 240;
    3 : 0;
    101 : 3;
    102 : 16128;
    103 : 0;
    111 : 360;
    112 : 720;
    113 : 720;
    The parameter 102 =16128 is not possible to set; but we receive the value 6192
    see below:
    Imposta parametro 102, valore = 16128
    [15] ID 133: Rapporto dei parametri 102 ricevuto, valore = 6912
    A question for Fibaro support: I have an EU version of the 3 phase AEON Labs Home Energy Meter DSB09104-ZWEU.
    I have manged to configure it to show the total  and instant consumption, in room view.
    But it is not usable in the consumption tab. More than that, in the energy panel,  when i choose the room where it is allocated, the web page is freezing.
    Could you integrate it, so it would be usable in the energy panel?
    Thank you very much!
    I have upgraded to 4.049, then I have deleted the device and reinstalled it an it seems that it is working now. Though, the pie chart in the energy panel si not taking into account that the total value on the energy meter is the sum of the 3 phases and it is showing it like the 4th value.
