HRT4-ZW and ASR-ZW nothing works
I have nothing to say , only that the situation , which was already bad got worse still , congratulations
4 answers to this question
Did you do a new re-include (remove it correctly and add it again) ? That did the trick for me.
    My main problem has always been an erratic path of ignitions and shutdowns of the boiler
    Actuator does is simply with the on-off button on the box if it is linked with the thermostat by turning the wheel
    Well, when it start the boiler, because in the room there are 17 ° and the cycle requires 19 ° , the thermostat , you agree that the actuator part ( but I did not noted on the web panel , which makes the dimmer that I associated together) , the problem that before arriving at t ° set makes a series of on and off incredible example yesterday was accessed then after going off without a fixed schedule , then after 10 minutes rekindled and goes off again after a certain of minutes and so on ...
    I hope you understand.. google translator docet...
    I have a few of these working though polling does not work on receiver so status does not match state. My wife reported she is warm but snow is falling so they are working.
    I have posted how to add so many times. I am hoping that the new forum will make it easy to find but search does work.
    [ Added: 2015-01-13, 21:33 ]
    Ok check your dip switches against the manual and adjust for the type of boiler. I think 10 mins might indicate set for electric heating.
    this is the result of the test yesterday .... while I thought I had discovered the secret of the Dip Switch about the famous TPi boiler , but just when I was enthusiastic about the "discovery " was promptly denied ... Having said that however, the ' actuator still does not mark the change of state from the start of the test and the thermostat as indicated by the panel of HC2 was set up to 19.5 to 22 when he returned to 17 ° and the temperature of the room has always been up to the end of " test " between 19.5 and 19.9 ...
    Then , I started by setting 12 cycles per hour and here I understand the operation ... which is 60 minutes / 12 = 5 and in fact the thermostat gave the input power every 5 minutes ...
    In fact here is that regularly attacks every 5 minutes ....
    so at this point I tried to confirm with 3 cycles now , and in fact the result was this :
    the thermostat gave consent every 20 minutes as " protocol " , obviously the ignition time was very short because the temperature in the room was a regime compared to just 19.5 set on the thermostat ...
    at this point the ultimate test , imposed the dip switches is 7 to 8 on and off ... see picture from 18.20 to 19.16 and then came on so I thought I finally managed to square the circle but ... then watch out ignitions in two successive images ...
    and so it went on until 22 when the thermostat is set at 17 ° ..
    but why ?????? because if it is set to no cycle is yet to come on every 10 minutes ! ?! ?! ?!
    regards
    Alberto
