I have a bunch of Fibaro Door Window sensors. And i have discovered a bit of an issue.
Two of them have been used to "debug" some issues i have been seeing with battery sensors and multi hop routing, so they have been moved between controllers frequently.
In other words, i have removed the cover probably more then 100 times in the last few weeks.
Now they both show the same issue, due to wear and tear around the fasteners, the "pin" no longer reliably depresses the internal tamper switch when the cover is back on.
Fibaro, you _really_ should have used a spring design for that purpose.
