Coffee machine turnoff by power and timer
I was thinking of a scene that is triggered upon power consumption in a wall plug.
I got one connected to my coffemachine and was thinking that if the power consumption goes above threshold value a timer would start and check the power once more after 1h.
If its still on... its forgotten, send push and turn it off... But I'm stuck!
%% properties
69 valueSensor
%% globals
local power = fibaro:getValue(69, "valueSensor")
local threshold = 50 -- Threshold in watt
if (tonumber(power) > threshold) then
fibaro:debug("HC2 Coffee script started: " .. os.date());
fibaro:debug("Consumption="..power.." Watt")
fibaro:debug("Coffee Machine is ON") -- lite debug text
... Timer to check again after 1h?
fibaro:call(69, "TurnOff")
fibaro:debug("Send push message")
fibaro:call(47, "sendPush", "Coffe Machine automatically turned of at: " .. string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min));
4 answers to this question
Sorry to hijack your question but I'm on a crusade to find design patterns for common task using setTimer instead of sleep (and global variables) so I thought your example was a good exercise
/emoticons/default_icon_wink.gif" alt=";-)" /> Disclaimer: undeployed code that may contain bugs.
This could be such a pattern. Drawback is that it uses polling instead of events so it could miss the machine being turned off and on within the polling interval. Also a bit unsure about the 'power' property still being ok in v4.
The holy grail now is to find a mechanism (loophole?) to connect a triggered scene with an already scheduled task... then we can get tasks (closure with states) that also reacts to device events
Edit: dang! The scene can be triggered many times while the coffee machine is on if the power varies. In the sleep model one could always synchronize on the count of how many instances of the scene that was currently running... not a pattern yet
/emoticons/default_icon_confused.gif" alt=":-?" />
KristianO, My power monitoring is now borked but I was previously doing that with a scene.
Essentially if my hose pump was using more than 50w for more than 20 mins then I shut it down and sent an email.
Here you can find my lua that i use to my coffiemaker, it doesent send push but it do the work. you can update with push if you want.
ps are you using ver4.xxx you must change "valueSensor" to power
    AtomicGrog: I think the problem with this is that when i actually do remember to turn it of, the code will still turn off the plug too. I dont want that.
    SonnyBoy: I will test you code but it seems like to have the right solution. Nice! Thanks!
    Jgab: No problem at all! Does this asyncronos "wait" mean that it will not stay in the scene?
    Since i dont really understand the difference with the old sleep and new timeout
