What is wrong with this scene ?
It was ok until i updated to 4.031, now is dead.
%% properties
51 sceneActivation
56 sceneActivation
54 sceneActivation
%% globals
-- Device IDs that should be turned off when AllOnOff button pressed
allOffDevices = {57, 51, 55}
local trigger = fibaro:getSourceTrigger();
if (trigger['type'] ~= "property") then
fibaro:debug ("Unexpected source trigger '" .. trigger['type'] .. "'");
fibaro:abort ();
local id = tonumber (trigger['deviceID']);
local scene = tonumber (fibaro:getValue (id, "sceneActivation"));
if (scene == 26) then
-- 26 is sceneActivation code for 2nd FGD-211 button click
for i = 1, # allOffDevices do
fibaro:call (allOffDevices, "turnOff");
5 answers to this question
fdstil,
I think the scene activation, I have the same problems with my Fibaro UBS.... nothing is working anymore
    Soft reconfigure is the key !!!!
    Not for me
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I have created already a bug on bugzilla, more persons have problems. Great to see that it's working for you!
    Look at my posts in the following topic.
    First thing to check is the scene activation property in API. Get Json Viewer addon installed and go to HC_IP/api/devices/idOfDevice and check if there is scene activation visible. If not, perform reconfiguration, first soft and then regular one if needed.
